benjamini Posted August 2, 2005 Report Share Posted August 2, 2005 Hi. I've got an old MDS-PC3 and I'm wondering if it is supported by SonicStage 3.2. I would really like to find a fast way to transfer recorded media off my MD's to my PC.thanx Quote Link to comment Share on other sites More sharing options...
Christopher Posted August 2, 2005 Report Share Posted August 2, 2005 Welcome to the forums. You won't be able to transfer media off of MD/LP discs with that unit and Sonicstage 3.2, as NetMD cannot upload in this sense, only Hi-MD can.Furthermore, Sonicstage may not be able to immediately communicate with your device with the native "Personal Audio Drivers" (they come with Sonicstage). You may need to install the drivers for the PC3 first, and then install Sonicstage. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted August 2, 2005 Report Share Posted August 2, 2005 You won't be able to transfer media off of MD/LP discs with that unit and Sonicstage 3.2, as NetMD cannot upload in this sense, only Hi-MD canjust to avoid any problems later on... even with a HiMD and SS3.2 you won't be able to upload those recordings faster than realtime. Only recordings made in the HiMD formats (HiSP/HiLP) or PCM can be uploaded through USByou can always use the analogue (or even optical if you have a deck with optical out and PC with optical in) way of transfering the recordings to PC, but that's it... Quote Link to comment Share on other sites More sharing options...
Christopher Posted August 2, 2005 Report Share Posted August 2, 2005 Good thing to mention, Volta; my inital reply may have lead him to believe otherwise. You can learn more about real-time uploading here:http://forums.minidisc.org/index.php?showtopic=7070 Quote Link to comment Share on other sites More sharing options...
zerodB Posted August 3, 2005 Report Share Posted August 3, 2005 The MDS-PC3 will not function with SonicStage as your unit is not NetMD/Hi-MD/OpenMG compliant by any means.I'm afraid you have to stick with the software & drivers supplied with your unit (M-Crew). Quote Link to comment Share on other sites More sharing options...
Christopher Posted August 3, 2005 Report Share Posted August 3, 2005 Doh! Even better point, Zero! Yes, it looks like the only way to transfer music to and from the PC3 is either via the Analog or Digital out.. Quote Link to comment Share on other sites More sharing options...
